1450 Hydro valve
Masseyman79
07-22-2003 14:15:58
When I got my Cadet 1450 it could not be pushed without utilizing the hydro valve dump lever. Now I can easily push it by hand. Drives good but can take some effort up hills without advancing drive. Will replacing the dump valves cure this and is it as easy as it looks? (service manual hasn't come yet)
Bob
07-23-2003 12:47:11
 Re: 1450 Hydro valve in reply to Masseyman79, 07-22-2003 14:15:58
One valve is for forward motion, the other for reverse. By swapping them, hopefully you wind up with the more functional valve in the position that controls forward motion. (Off hand, I don't know which position, RH or LH is used for forward.) Carefully clean away dirt, and carefully reinstall them so as not to damage "O" rings.
masseyman79
07-23-2003 09:47:58
Lucas, as in swap right for left?
lucas
07-23-2003 06:54:14
seems to me you can swap position of dump valves on these and ariens to cure this problem.lucas
lucas
07-23-2003 13:29:51
 Re: Re: 1450 Hydro valve in reply to lucas, 07-23-2003 06:54:14
thats a big 10-4.. swap position of the old valves.. lucas usmc
