Battery Discharging
Kirk
07-23-2003 14:05:51
I have a Snapper LT12 and as I was mowing the electric clutch for the Blades shut off, then the engine quit shortly after. It wont start back up without charging the battery. It seems as though the battery is not being charged when it is running. I can charge the battery and it will run for awhile then do the same thing. Is there something in the charging system or something else I can check?
Kirk
08-01-2003 09:16:31
 Re: Battery Discharging in reply to Kirk, 07-23-2003 14:05:51
Yup! Found the problem was a shorted out Electric PTO Clutch. Thanks People for the Tips of what to check. Very helpfull!!!!
Ollie
07-24-2003 05:05:09
Most likely the generator is not working. Run your DMM on DC voltage scale across the battery terminal with the engine of and the battery fully charged. You should see 12v or a little more. Then do the same with the engine running. You should see something like 14v. If not, you found the problem.
Gene Davis(GA)
07-23-2003 20:08:43
Sounds like an electric pto clutch failure/short is killing all the battery power.
artb
07-24-2003 09:17:33
 Re: Re: Battery Discharging in reply to Gene Davis(GA), 07-23-2003 20:08:43
not familiar with your specific tractor but i would check for a bad diode
