16hp Briggs Exhaust valve seat
Mike K
09-20-1998 18:11:26
I have a twin cylinder Briggs and Straton
402707 model. The exhaust valve seat has come undone from the cylinder head. Is this repairable,
are there oversized seats? Any options, new motor is expensive.
Jim
09-21-1998 19:40:48
 Re: 16hp Briggs Exhaust valve seat in reply to Mike K, 09-20-1998 18:11:26
My Dad had a 10 horse Briggs with this problem. I merely put the seat back into place and then staking it into place with a pointed punch and hammer.This was over five years ago. Still running fine.
Gary H.
09-21-1998 19:17:51
: I have a twin cylinder Briggs and Straton
: 402707 model. The exhaust valve seat has come undone from the cylinder head. Is this repairable,
: are there oversized seats? Any options, new motor is expensive.
You are on the right track. Check with a local machine shop and they should be able to come up with an oversize seat. You're not the first with this problem. Good luck.
Al Hamilton
07-17-2000 08:43:36
 Re: Re: 16hp Briggs Exhaust valve seat in reply to Gary H., 09-21-1998 19:17:51
: : I have a twin cylinder Briggs and Straton
: : 402707 model. The exhaust valve seat has come undone from the cylinder head. Is this repairable,
: : are there oversized seats? Any options, new motor is expensive.
: You are on the right track. Check with a local machine shop and they should be able to come up with an oversize seat. You're not the first with this problem. Good luck.
: I have a 2 year old 19.5 hp to just did the same thing.
jeff mccrady
04-19-2003 13:16:11
 Re: Re: Re: 16hp Briggs Exhaust valve seat in reply to Al Hamilton, 07-17-2000 08:43:36
i fixed mine by taking a punch and tapping aluminum back around the seat and that held it in just fine!!!!! ! still running fine!most guys will tell you to junk the motor,but put the seat back in it and tapp the aluminum back around it! and it will be ok! trust me!
