BS 6 h.p. vert-flaming intake.
Maricopa
08-04-2003 21:51:10
I have a 6 h.p. ohv vert b&s that actually shoots fire from breather. I have checked cam timing, flywheel shear key and have lapped valves to no avail. Could it be a weak field in the coil collapsing too soon? Would I use a timing light to check it????? By marking tdc on screen and shroud, when I crank it, it should spark approx 10 to 20 degrees btdc, right??
HELP....
MJM
08-05-2003 18:11:49
 Re: BS 6 h.p. vert-flaming intake. in reply to Maricopa, 08-04-2003 21:51:10
May want to check your valve clearances. The intake may not be closing all the way. Good luck: MJM
