Flywheel key shearing
James
03-09-1999 19:34:03
1980 + JD 265 air cooled kawasaki shears keys regularly like every time it is attempted to start like engage starter pop replace key engage started pop replace key
Need help what is causing this and what does it need to fix it? thanks jg
al
03-09-1999 21:32:06
 Re: flywheel key shearing in reply to James, 03-09-1999 19:34:03
With most others[Briggs.,Techum.,etc..] the ignition timing is off. The engine fires
out of time and the momentum of the flywheel shears it off..
john d.
03-10-1999 06:25:00
 Re: Re: flywheel key shearing in reply to al, 03-09-1999 21:32:06
Right on! If this isn't the problem (and I'd bet it is) check to see if the keyway in the flywheel or crankshaft is damaged, allowing for any play. In addition, be sure the flyweel nut is torqued properly when installed.
