Case 446 Steering
earl
08-13-2003 07:03:07
Does anyone know the proceadure to center the steering on a 446 Case, or do they normaly turn sharper one way than the other. Thanks.
Jim Handke
08-14-2003 05:24:01
 Re: Case 446 Steering in reply to earl, 08-13-2003 07:03:07
My 448 was the same way, turning shorter one way. I adjusted the steering arm this spring, and it turns the same now. You have to lie on your back, looking up at the lower end of the steering shaft. At least I did. If you don't care to remove the mower deck, maybe a mirror would do the trick. Turn the steering arm until the gear on the steering shaft is in the middle of the steering gear. Just make sure that the tires are pointing straight ahead.
