help i.d vintage bs
Al m
08-20-2003 15:27:14
I need help to i.d. a very old briggs.It's a cast iron single,cyl & oil pan both bolt to base with 4 bolts each.head is alum.Cast on one side of cyl is "mg1" in a sort of box as well as "basco".on the other side is "6862".It has 2 fly wheels,1 cast iron,1 alum.The shroud is tear drop shaped steel with a alum shroud covering a chain & sprocket to a elec. start.It apears to be missine a 2nd shroud,as the one will fit both sides.The bore is 2.75,stroke 3.25.
Thanks
Al
Rory
08-22-2003 21:07:11
 Re: help i.d vintage bs in reply to Al m, 08-20-2003 15:27:14
Al go to www.ascee.com look in technical data follow briggs&stratton data to engine description there's pic's there!
Al m
08-23-2003 17:23:18
 Re: Re: help i.d vintage bs in reply to Rory, 08-22-2003 21:07:11
Thanks,I think it is a model r from 1929-1933.
Al
