1420 Cub Cadet With Kohler Engine
Drew Dey
08-21-2003 09:36:29
I have a problem with my tractor whereby it will not stay running. It appear that it is not getting enough fuel. When I get it started it will fun for a few minutes or second and then stalls and sometimes back fires.
I have changed the plugs and added some water remover to the gas but it did not solve anything.
Any suggestions would be appreciated.
Thanks
Drew Dey
08-21-2003 12:07:15
 Re: 1420 Cub Cadet With Kohler Engine in reply to Drew Dey, 08-21-2003 09:36:29
Hi Dave,
The tractor was running and it all of a sudden it quit. This has happen in the past but I had to clean the fuel line from the tank to the filter. I have used the tractor all summer with minimal problems.
Thanks
Drew
Dave
08-21-2003 11:14:17
Drew,
Check the fuel tank for blockage. AS for the backfire, check the points and flywheel key.
Has the tractor been sitting for awhile or was it running and all of a sudden didn't work? Where do you store it? If it stopped while you were running what caused it to stop, (hit a stump or a pipe etc...)
Dave
