582 Cadet switch won't shut off
Dan
09-04-2003 16:12:11
hi, can't shut the engine off with the switch. it will shut down at the post on eng. when GRD.so thatis hockup. can't figiure out where hook the wire from engine in to the key,or where ever help appreciated Dan
Wally G.
09-07-2003 18:07:53
 Re: 582 Cadet switch won't shut off in reply to Dan , 09-04-2003 16:12:11
The Briggs engine does not have power fed to the magneto. When you ground the wire from the magnetron it kills the spark. DO NOT hook power to the magnetron or you will be buying a new one. Check the terminals on the key switch, the magneto kill wire should go to the one marked with a M. It's possible the switch went bad and is not grounding out when you turn to the off position, or the wire and terminal at the switch is rusty and not making a good connection.
Jim S.
09-08-2003 05:44:22
 Re: Re: 582 Cadet switch won't shut off in reply to Wally G., 09-07-2003 18:07:53
Thanks Wally. I got stuck on KOHLER that day, I guess. Time to rewire my brain.
Wally G.
09-14-2003 11:29:20
 Re: Re: Re: 582 Cadet switch won't shut off in reply to Jim S., 09-08-2003 05:44:22
That's OK Jim, I have days like that too.
Ron
09-08-2003 20:03:44
Yep, that's what I thought.
Jim S.
09-05-2003 05:24:09
Your engine does not shut down by grounding the ignition, but rather by the switch cutting off the power supply to the coil. You may have a bad switch that is not shutting off the current. Below is a link to a wiring diagram that might help. There is lots of Cub Cadet info at www.ihregistry.com/discus ... join us!
Ron
09-05-2003 17:16:05
 Re: Re: 582 Cadet switch won't shut off in reply to Jim S., 09-05-2003 05:24:09
For some reason I disagree with the switch not grounding out the coil. As far as I remember there is no power going to the coil. There is a wire that comes out of the coil going to the key switch. If you disconnect this wire the key will have no effect on shutting down the tractor.
