14.5 OHV BS oil in cyl.
Steve
09-07-2003 10:50:24
I start the mower the other day there was a white cloud of smoke, the engine has no knocking but i shut down. went out today and tried to turn over ,no go , pulled the plug and it wet.turn the engine over oil shot out of the cyl. what big problem do i have. any thoughts would be appreciated Thanks ST
Dave
09-08-2003 10:32:50
 Re: 14.5 OHV BS oil in cyl. in reply to Steve, 09-07-2003 10:50:24
Steve,
What carb do you have, how new is it, and is there any selonoid on the carb? I would also guess that the carb is leaking gas into the cylinder head and causing the engine to fill with gas and as the level raises in the crank it eventually seeps into the cylinder because a fluid seeks its own level. Bringing oil with it.
lots of luck
steve
09-09-2003 05:18:37
 Re: Re: 14.5 OHV BS oil in cyl. in reply to Dave, 09-08-2003 10:32:50
well im going to take it out and look, may never get back to gether but, thanks for info. Steve
Ryan
09-08-2003 06:17:00
This is a defect in the design of the OHV Briggs engines. Pull the head. Look at the gasket area between the cylinder and the chamber the pushrods run through. I would bet money that there is a leak there. If there is it will be discolored. A new headgasket is a 7 dollar part from a Briggs dealer.
Ollie
09-07-2003 15:35:02
If it's oil and not gas fouling the plug, you have a cracked ring/piston or very worn rings/cylinder walls.
ROLLIE
09-07-2003 17:32:01
 Re: Re: 14.5 OHV BS oil in cyl. in reply to Ollie, 09-07-2003 15:35:02
I THINK I KNOW WHAT IT IS-- OIL AND GAS BOTH-- DRAIN IT COMPLETELY-- CHANGE FILTER--THEN PUT A INLINE SUT-OFF IN GAS LINE-PUT NEW OIL IN- AND WHEN NOT IN USE SHUT OFF GAS-NOT ALLWAYS BUT WHEN YOUR LEAST EXPECT GAS WILL GO PAST CARB AND CAUSE THIS--LET ME KNOW IF IT HELPS
