!2.5 Kohler
D.B.
09-12-2003 08:14:49
I have a Kohler 12.5 on my Cub Cadet riding mower. It start fine and runs great. However, after it has been running for awhile I cannot restart it until it cools down. The engine turns over just won't fire. Is this a coil problem?
clifford c benjamin
09-22-2003 21:25:12
 Re: !2.5 Kohler in reply to D.B., 09-12-2003 08:14:49
does this have module on the side of the blower houseing of the engine if it does its electronic igniton pull off the houseing and if there is two coils. if i remeber right.i had the same problem not fireing. in the box that holds the coil there is a paper telling what to look for on a coil or coils you change them both meaning the coils on the motor
Gene Davis(Ga.)
09-14-2003 20:59:57
The ignition modules on this unit give a lot of trouble. The JD svc manual, or Kohler gives a set of test values for checking it. The one on my 12.5 almost drove me crazy before I found the trouble and replaced it It is about $38-40 from JD.
Ollie
09-12-2003 10:22:58
Look down a few posts to Kohler...
