Anyone sell 1/2 size belts?
slideways
09-13-2003 15:55:41
Hey guys, Unless one of you guys can look up the correct size for a Jacobsen LT860 belt i am striking out. I wore out my old belt so i got a new one from Tractor Supply. I think it got an 87". The old one kept falling off so i figured it was time for new. Now the one i have is too tight. I cant press the clutch and change gears because the belt pulls the trans so tight. When it is in Neutral and i push the clutch the belt just keeps driving and i have to jam it in gear. I tried an 88" but it is too loose and wont even drive. I upgraded and replaced the brakes but they are wearing out so fast because they have to do so much work to stop the tractor. I even changed the idler pulley to a smaller size but still no luck. I would like to go back to the original configuration if i could just find the right belt! No lawn shop has 1/2 sizes.
Thanks for the help
frank
09-17-2003 17:50:34
 Re: Anyone sell 1/2 size belts? in reply to slideways, 09-13-2003 15:55:41
third party image
you may want to look into "link" belts. they are sold by power transmission dealers and companies like Granger and McMaster-carr.
The links are removable and they can be adjusted to about 1/2".
They ar a bit higher than a standard "a" belt and a bit wider, but seem to do the job.
The pictures shows them mounted in my old MTD that I was in the process of rebuilding.
john
09-14-2003 05:27:36
if one is too short and the other too long, the problem may be that the belt is the wrong width, some belts are not the same as an automotive belt in width, making the belt fit further down in the pulley, this will cause the problem that you seem to be having
Ben in KY
09-13-2003 18:28:23
My local NAPA store can order most any size I need, if they don't have it in stock.
clifford c benjamin
09-22-2003 20:29:42
 Re: Re: Anyone sell 1/2 size belts? in reply to Ben in KY, 09-13-2003 18:28:23
stens 1 800 457 7444 they have 1/2 belts they call them tru blue double wrap belt with tough kevlar cord they also have other sizes also call them and ask for tech service they may be able to help you out. from your napa store always ask for fractional hp belts not automotive. differant size belt
