582 cub where one wire goes
Dan
09-14-2003 15:10:16
Hi all, the ? is 582 cub with B&s twin . the rectifier has 2 yellow wires from engine , the red wire where does it go to from the rectifier. thanz a bunch Dan
Wally G.
09-15-2003 15:19:07
 Re: 582 cub where one wire goes in reply to Dan, 09-14-2003 15:10:16
That wire goes to the R (rectifier) terminal on the key switch. It should have a plastic coupling and it is a diode wire. Briggs does sell the diode wire separate if yours is missing. The wire from your key switch may be black.
Dan thanks a bunch
09-15-2003 18:16:51
 Re: Re: 582 cub where one wire goes in reply to Wally G., 09-15-2003 15:19:07
thanks a lot Wally i don't see any diode .,Dan
Wally G.
09-16-2003 16:14:39
 Re: Re: Re: 582 cub where one wire goes in reply to Dan thanks a bunch, 09-15-2003 18:16:51
The diode is built into the wire that comes off the regulator.
