Charging problem 982 Cub/Onan
Tim
09-18-2003 08:27:56
I have a 982 Cub with Onan B48G Starts and runs great, I have a problem with charging, When tractor is running with no electrical load, re: Lights/Elect Clutch ect. Gauge shows needle in center. When you turn on anything lights clutch, Gauge reads neg charge. I have tested the Stator-OK Cleaned and even replaced the terminal ends from Stator to Rectifier Replaced Ignition switch and replaced Terminal ends"Was melted a little about like every other 82 series that I"ve had" Also, the leads that come from the Stator had also been Hot, not melted away, but plug was not as new. That is the reason that I replaced the Terminal ends. Battery is good,I have had several people tell me that I need to check clearance on the Elect. Clutch. This problem still occurs with both front and rear Clutches unplugged. Just turn the key back to turn on lights and gauge shows Neg- charge.So, automatically, I think that it has to do with the Lights, So, I unplugged the lights and plugged in the Clutches, Still the same!! I'm not sure how to test the Rectifier. Man at Cub dealer say's you can't. But he can order me a new one Imagine that!!! I'm new to this board, but seem's like there is a wealth of knowledge on here. Maybe someone can help. Thanks in advance, Tim.
rick
09-18-2003 09:12:29
 Re: Charging problem 982 Cub/Onan in reply to Tim, 09-18-2003 08:27:56
If the stator test out good then check all of the connections to include the battery. It sounds like you may have done that already. Then test at the battery with the engine running at opperating speed (full throttel). Should have 13.5 volts or higher. If not the regulater is bad. If you have 13.5 at the batt then turn the switch to the run position with the engine off and test you power to the clutch and light plug ins and also run a continuity test with everthing shut off.
Kent David Redd
09-21-2003 14:18:02
 Re: Re: Charging problem 982 Cub/Onan in reply to rick, 09-18-2003 09:12:29
You have a BAD rectifier/regulator. Toe the line and buy a new one.
