DECOMPRESSION VALVE
16 HP TECUMSEH
09-24-2003 15:22:49
HOW DO I FIX THE DECOMPRESSION VALVE. IT HAS TO MUCH COMPRESSION ON START UP
clifford c benjamin
09-26-2003 07:45:16
 Re: DECOMPRESSION VALVE in reply to 16 HP TECUMSEH , 09-24-2003 15:22:49
you will find it on the cam inside the engine. on start up the cam has a fowler that holds the exhaust valve open after a start up and run up the valve will close after a certian rpm and should run ok after that if it don't it could be broken or stuck some times over reving the engine could cause it to get thrown by over reves and cause it to break
