16 hp tecumseh decompression vavle
kenny
09-24-2003 16:59:37
hard to start i think the decompression is not working wright. how do i check it.
Kent of SW MO
09-27-2003 16:14:11
 Re: 16 hp tecumseh decompression vavle in reply to kenny, 09-24-2003 16:59:37
The valve clearance has been set incorrectly. Turn the engine to top dead center on the firing stoke (both valves closed and then turn it just a
little farther and then adjust the valve clearance
on both valves. This should take care of your problem. A 16 hp Tecumseh should have ajusters on the lifters which you can adjust after removing the valve spring chamber cover.
lucas
09-24-2003 17:42:31
it should raise the exhaust valve some .050 on compression stroke near tdc while turning engine by hand. you can see the exhaust valve thru the valve cover ,with the head off, thru the sparkplug hole maybe or by looking into the exhaust outlet.. lucas
kenny
09-25-2003 17:10:10
 Re: Re: 16 hp tecumseh decompression vavle in reply to lucas, 09-24-2003 17:42:31
where is the (it) located. thanks kenny
Max
09-26-2003 06:08:10
 Re: Re: Re: 16 hp tecumseh decompression vavle in reply to kenny, 09-25-2003 17:10:10
Cam gear, centrifigal force lowers the mechanism that opens the exhaust valve. Once the engine reaches 250-500 rpm, the engine then the exhaust valve will seat completely.
