BS Ignition Problems
Armand (IA)
10-10-2003 15:21:45
Bought a used Wards two stage show blower with 5HP B&S. Recoil was bad so replaced it. Now find that I have no spark. Removed the coil and cleaned the surfaces on it and the flywheel. Didn't help. Spaced the coil at .010 when I replaced it. Is that too much? Spark plug appears to be new. Should I assume the coil is bad? Suggestions would be appreciated. tks much!!
Kent of SW MO
10-12-2003 14:14:01
 Re: BS Ignition Problems in reply to Armand (IA), 10-10-2003 15:21:45
Look at the code number on the shroud. The first
two numbers are the year the engine was built. If it is 1962 or later, Briggs makes an electronic
ignition retrofit kit for this engine. It is about $15.
treeboy
10-10-2003 17:04:48
how old is this b&s. does it have points & cond. under the flywheel?? also poss. the flywheel key is sheared makeing the timing off..
Armand (IA)
10-11-2003 18:53:53
 Re: Re: BS Ignition Problems in reply to treeboy, 10-10-2003 17:04:48
Treeboy, I pulled the flywheel this morning and found the points and condenser. Replaced both and she started on the first pull. tks,.
Armand (IA)
10-10-2003 19:17:54
Don't know the age, but guessing 10-15. I'll pull the flywheel tomorrow and check the points.
Don't see anything external so they must be behind the flywheel. tks.
