6216
tweeter
10-10-2003 21:08:42
Still cant the 16 hp twin Briggs to run. I changed all four valves in the engine and put everything back together correct. i never moved the pistons while changing the valves or while anything was apart. Could the timing be off? Do i have to adjust the tappet? the tractor did run before the valve change by starting it by dripping some gas in the carb.
john669
10-11-2003 08:00:39
 Re: 6216 in reply to tweeter, 10-10-2003 21:08:42
if it run ok will dripping gas down the carb., sounds like you had a fuel problem in stead of a valve problem, fuel line stopped up, selinoid not working, some have fuel pump, maybe it not working, did it set up with old fuel in it, carb could be gummed up, just some things I would ck.
