BRIGGS AN STRATON 10HP TUNE-UP
KENT
03-19-1999 15:25:45
I WOULD LIKE TO KNOW THE SETTINGS ON THE CARB OF A 10HP B&S ENGINE ON A OLDER CRAFTSMAN LAWN MOWER THE SETTING SCREW ON THE BOTTOM OF THE CARB AND THE ONE ON THE SIDE HOW MANY TURNS FROM THE CLOSED POSTION
Bob Dole
04-29-1999 08:30:49
 Re: BRIGGS AN STRATON 10HP TUNE-UP in reply to KENT , 03-19-1999 15:25:45
Bill Clinton
04-29-1999 08:35:57
 Re: Re: BRIGGS AN STRATON 10HP TUNE-UP in reply to Bob Dole, 04-29-1999 08:30:49
Start the lawn mower and adjust until the engine ildle smoothly at low RPM's then rev it up and adjust the scew more until it runs smoothly.
If you are having trouble starting the lawnmower you might need a new spark plug.
M.T.DEES
05-05-1999 21:41:15
 Re: Re: Re: BRIGGS AN STRATON 10HP TUNE-UP in reply to Bill Clinton, 04-29-1999 08:35:57
TIGHTEN BOTH SCREWS IN ALL THE WAY. THEN OUT @ 1.25 THEN ADJUST TO ENGINE IDEL OR FAST BEST POWER
Mark L.
03-19-1999 16:14:08
Kent: The two adjusting screws should be opened from the closed position @ 2 turns each to get engine started.With engine an full throttle adust bottom inward to lean out and listen to engine run smooth without backfiring..do this also under load until it runs smooth.Adjust idle screw on the side of the carb. by setting throttle to lowest speed setting.Turn screw in clockwise to lean out the idle circuit of carb. until it idles smooth without surging.When running smooth at idle,increase throttle and make sure that engine still runs smooth at high speed.Readjust if needed.Hope this helps,Mark L. Buffalo NY
Ed
05-10-1999 18:16:31
 Re: Re: BRIGGS AN STRATON 10HP TUNE-UP in reply to Mark L., 03-19-1999 16:14:08
I have a B&S 14.5 hp engine and i think a valve is stuck any suggestions on how to get it unstuck? Also the reason it got stuck was that i have gas getting into my oil. Someone told me that maybe my float is not working right. I checked but it seems ok. How can I stop the gas from mixing with my oil?
