16HP Briggs
Tweeter
10-17-2003 15:55:26
The engine is a Briggs & Stratton 16HP horizontal twin. Model number 402700 Code # 0130. I still cannot get the motor to run even after putting a fuel pump repair kit in. The motor will run for a couple of seconds on the gas that i trickled into the carb. Engine doesnt seem to be getting gas. Everything in the carb seems to be clean. What else can i do. Fuel solenoid works properly.
Rusty Jones/ The Mower Ma
10-19-2003 20:11:52
 Re: 16HP Briggs in reply to Tweeter, 10-17-2003 15:55:26
I had a problem like yours! Thought the fuel pump was bad. Not! The ignition switch didn't make the correct connection when turned to start! If i let it go back off start a teeny bit, the engine would start and run! To check the fuel pump, disconnect the fuel line at carb, put end in coffee can, turn ignition switch to start, making engine turn over--fuel should run into coffee can! RJ
kicker
10-18-2003 21:20:11
The carb is going to have a vacuum line to the crank case. Check to see if it is cracked.
kjm
10-18-2003 20:12:14
Just a thought,look for a shut off in the line,discnnect the fuel line at the carbuter and catch it in a can(no fires)crank it over and see if you have fuel.I have seen plugged nipples at the tank,fuel lines that have collasped on the in side,and of course plugged filters. Good luck kjm
Kent of SW MO
10-18-2003 16:57:09
Be sure you do not have a plugged fuel filter or fuel line. Also check that you have not switched the fuel line with the vacuum pluse line at the carb.
lucas
10-17-2003 17:01:24
is the fuel pump working?
Tweeter
10-17-2003 17:28:55
 Re: Re: 16HP Briggs in reply to lucas, 10-17-2003 17:01:24
How can I tell if the pump is working properly.
