BS voltage out put
dan
10-31-2003 09:36:50
B&s 18hp vert. 422707 what should the voltage be coming out of the engine stator . Im showing 7-8 at a idle. is this what it supposed to be . i thought it would be more.>>>> when i hook the shut off wire at the engine the amp gauge shows a discharge. thanks much Dan
rick
10-31-2003 09:46:46
 Re: BS voltage out put in reply to dan , 10-31-2003 09:36:50
should be checked at operating rpm's. about 28 volts from the stator before the regulator.
dan
10-31-2003 13:55:29
 Re: Re: BS voltage out put in reply to rick, 10-31-2003 09:46:46
this doesn't have a regulator. dan
