Cylinder Head Bolt Torque
Bob Coen
03-23-1999 12:27:24
I have a 1972 Wheelhorse Commando 800 with a Kohler K181S 8hp engine. Does anyone know what the recommended torque is on the cylinder head bolts? Thanks!!!
Randy
03-24-1999 15:49:41
 Re: Cylinder Head Bolt Torque in reply to Bob Coen, 03-23-1999 12:27:24
Go to>Link
Randy
Don
03-23-1999 18:05:15
Bob, Make sure you you torque the head bolts in sequence(in the kohler manual), run engine 10 minutes, shut off and let cool down until the block is cold, then re-torque to proper specs. Kohler engines are known for blowing head gaskets! Good luck, Don
PS:Don't torque the head bolts to the finish torque specs all at once. "Sneak up" on the final setting in a few incements.
John in Pa.
03-23-1999 14:34:51
Hey Bob, the Kohler manual says 180 to 240 inch-pounds.
