430 tech manual
Dean
11-20-2003 14:33:30
Does anyone know where I can aquire a tech manual for a JD 430 garden tractor. $115 dollars from JD seems a bit over priced.
Dave
11-20-2003 19:56:18
 Re: 430 tech manual in reply to Dean, 11-20-2003 14:33:30
Dean - You can hang out on eBay to see if one shows up. Just be aware that the serial number of your tractor and the serial number range the tech manual covers, may be out of sinc.
You might call Deere back (1-800-522-7448) and see if they offer the tech manual on CD and what that cost is. I've heard, but not sure, that the CDs are less expensive. - Dave
Dan
11-26-2003 18:56:19
 Re: Re: 430 tech manual in reply to Dave, 11-20-2003 19:56:18
Hello Dave, Agree with above. I found the soft cover temporary manual,# TM-1309. It is a user but I think I gave only $18. Same material. JD component technical manual,# CTM3; covers the diesel engine and loaded with Specs, $32.
