Peerless transaxle axle bearing
A Cash
12-18-2003 13:11:52
I have a 12hp Murray rider with a Peerless 920 039 5-speed transaxle. Bought from K-mart about 1988 it has been a champ. The bearing for the axles is the transaxle housing itself. It IS cut out for bearings but never had bearings in it. A friend turned me two bronze sleeve bearings that work. I want true ball or roller bearings. IDxODxW is .75x1.575x.480. No luck in searching the web. Anyone know the make or stock number of the bearing that will work?
JLG
12-18-2003 19:07:56
 Re: Peerless transaxle axle bearing in reply to A Cash, 12-18-2003 13:11:52
Don't know the #'s off hand but I have purchased these from local bearing shop. Try a NAPA or Carquest parts store if you don't have local bearing company.
A. Logue
06-10-2004 11:23:11
 Re: Re: Peerless transaxle axle bearing in reply to JLG, 12-18-2003 19:07:56
the correct part number from NAPA is 7-04140 spindle bearing. My sears with peerless number 930-057 transaxle chewedup the drive gears and of course sears as a tightwad as they are left the axle bearing out of their unit! For less than $15.00 at NAPA, the bearing would have saved me over $ 100.00 in parts and my time to repair the unit. NO MORE SEARS MOWERS!!!!! !!!!! !
Hope this helps someone looking for the bearings.
A Cash
12-19-2003 07:38:51
Bingo! Found they have one that will fit perfectly, is sealed, and appears to be strong enough for the run. THANKS!
