10 hp kohler engine
l gale
12-19-2003 16:16:01
gas as blowing out of carb ,float seems ok everything seems to be set up correctly.still won't start lots of spark
jim
12-20-2003 06:51:35
 Re: 10 hp kohler engine in reply to l gale , 12-19-2003 16:16:01
the main thing that will cause gas to shoot out of the carb is:
1. float is cracked and is full of fuel, take off and shake it.
2. needle and seat is eroded and leaking fuel past the seat.
3. you have a vent plugged in you carb and the float bowl is not venting.
Rich
12-19-2003 20:00:46
When gas shoots out of carb when turning over is a good sign of an intake valve stuck open! I would do a compression check .
larry
12-30-2003 19:56:54
 Re: Re: 10 hp kohler engine in reply to Rich, 12-19-2003 20:00:46
you got it right intake was stuck open
KennyW
12-23-2003 17:42:07
Keeping in mind what Rich said, I would check the valve lash adjustments on the engine, should be .009 intake, .018 exhaust, check cold. Kenny
