simplicity broadmoor solenoid replacement problems
gardenered
12-24-2003 11:48:53
I just replaced the solenoid on my Broadmoor. It is wired as per the instruction diagram. The problem is when I connect the positive side of the battery, the engine turns over and starts. The cable from the starter and the cabnle from the + side of the battery are shown on the same pole on the solenoid.
Gardenered
JLG
12-24-2003 17:55:22
 Re: simplicity broadmoor solenoid replacement prob in reply to gardenered, 12-24-2003 11:48:53
Sounds like you got a lousey set of directions. Cable from battery should go on one side and cable to starter to other.
gardenered
12-27-2003 08:55:38
 Re: Re: simplicity broadmoor solenoid replacement in reply to JLG, 12-24-2003 17:55:22
I finally have the mower (with snow blade) up and running. I have the Simplicity manual here in front of me. The parts diagram shows the + and -- from the battery on the same pole with the starter-generator and a fused line to the amp meter on the other pole by itself. The schematic on the same page shows the + and -- on opposite sides of the solenoid, which is correct. No problem now. Thanks.
romrepcon
03-13-2005 14:02:59
 Re: Re: Re: simplicity broadmoor solenoid replacem in reply to gardenered, 12-27-2003 08:55:38
I would really apreciate your help on this one: I live in Europe and i need to replace the solenoid on a Toro tractor the problem is that i can't find one in my country - do you know any site/store where I can buy it online?
