400 hydro tranny
Arnie
01-06-2004 05:35:20
I was checking under my 400 and see that the tranny filter is the same as the oil filter on my van. Should i change it and go to a JD hydo filter and fluid or leave it? it seems to run OK but will I hurt anything? thanks for any info given
Arnie
01-06-2004 10:30:08
 Re: 400 hydro tranny in reply to Arnie, 01-06-2004 05:35:20
Thanks Rick/Bob i looked again and I have a Fram and it is the same as the one on my 1991 Plymouth Voyager van. i have one for the next van oil change will have to check number . do you have a cross ref. for Fram?
rick
01-06-2004 08:57:16
egine oil filters and hydro oil filters may seen to be the same, BUT THEY ARE NOT the same inside. The wix # that were post are for Hydros and are ok. You can croos them to NAPA #s too. Do not use engine filters on it. Hydro oil and filter should be changed once a year for long life and performance of the system.
Bob
01-06-2004 06:53:33
I was going to say, get the correct one from Deere, BUT...
I just looked in my WIX filter book...
Early 400 tranny filter = WIX 51307 (Principal Application ... 64-92 Volvo)(Deere AM38441)
Late 400 tranny filter = WIX 51410 (Principal application ... Toro Lawn and Garden, Ariens and IHC)(Deere AM39653)
I would guess if any of this crosses to the filter you have, you are OK.
