Ariens YT 11
Crazymts
01-10-2004 20:35:34
I bought some land and this Ariens YT11 was on the place! It has a 11 hp Briggs in it with hydro drive with hi-low range! Its in pretty good shape.
I got the engine to run a little only if I kept pouring gas down the carb!
Does anybody know what year this thing is and where a person can find parts for it?
Thanks! Anything will help!!
gerard
01-11-2004 03:09:50
 Re: Ariens YT 11 in reply to Crazymts, 01-10-2004 20:35:34
the first two numbers of the engine code, should tell you the year of the engine. if the engine has been stored with gas in it, may be a new carb is in order. by squirting gas in the carb, indicates, mechanically the engine is good enough condtion to run. providing it has a good carb. but first, clean the carb good. small dia spring steel works good for clearing passages.
