cub cadet
Allis
02-13-2004 12:29:03
Are all cub cadet transmissions the same? found a few old junkers and want to build a pulling tractor with a 16 hp kohler but need to know what the best model to start with would be?
Andy D
02-23-2004 18:18:48
 Re: cub cadet in reply to Allis, 02-13-2004 12:29:03
86/108/128 or 800/1000/1200 the motor fits easy but the tranny is external brake. External brakes will work but alot of pullers prefer an internal brake tranny to fit custom rims easier( no disc brakes on axles). The internal brake tranny is older out of a 100,70,102,122,124 there may be more but I don't know them off hand. You can put an internal brake tranny in an 86/108/128 or 800/1000/1200 but to fit a 16hp in an internal brake tractor you have to notch the frame to clear the fly wheel.
phil
02-13-2004 13:27:06
Try to find a 108 or a 128. They are gear drive wideframes that will accomodate a 16hp engine.
Taylor Devig
02-15-2004 16:18:31
 Re: Re: cub cadet in reply to phil, 02-13-2004 13:27:06
what number of junkers did u find if not what u need i would be interseted
