Need crankshaft or advice for Kohler K341aqs engin
Alvin Dunic
02-21-2004 20:41:43
Recently acquired a Ford garden tractor (freebie) but it needs a new crankshaft. Mechanical buddy of mine says its too worn and flattened for machining (will need to be resized 20,000th). Says I can buy I new crank (too expensive) or replace with a short block. Any advice or tips out there? Good deal on a crankshaft? Good deal on a replacement
Earl S.
02-23-2004 21:51:49
 Re: Need crankshaft or advice for Kohler K341aqs e in reply to Alvin Dunic, 02-21-2004 20:41:43
If your std shaft size is 1.499 to 1.500 Use a N-62 continental rod brg, bore your rod to fit, file for brg tang. 10,20,30, undersize Clevite # is CB 524. Federal use to make .040 and .060 semi bore to size. Bore rod on bridgeport to 1.622 then hone to 1.624--1.6245. Have saved a lot of them .
Wally G.
02-24-2004 17:09:56
 Re: Re: Need crankshaft or advice for Kohler K341a in reply to Earl S., 02-23-2004 21:51:49
Hey Earl, Thanks for that info, didn't know there was a bearing that close to the Kohler size.
Alvin
02-23-2004 15:51:12
Thanks for the info, to you guys who replied. I think I will try try resizing to .0020, as discussed at Link (thanks BCA). I was led to believe there were no bearing inserts for that size but now see there are some options. Will pursue some of the other excellent suggestions (ie, build-ups, etc) if the bearing insert route does not pan out
Wally G.
02-23-2004 14:46:10
Another route you can take is have the crank machined a little at a time after the first .010 until it is round, then have the new .010 rod shaved and the big end resized. I have had it done on three of my engine and they are working great. They ended up between .014 to .017 undersized.
CARL
02-23-2004 04:30:16
I HAVE A CRANK THAT IS GOOD OUT OF A K 341 WHICH IS SAME MOTOR EXCEPT IT DID NOT HAVE BIG MUFFLER
Alvin
02-23-2004 17:36:25
 Re: Re: Need crankshaft or advice for Kohler K341a in reply to CARL, 02-23-2004 04:30:16
Thanks for the offer Carl. Will take you up on the offer if going the oversized bearing route does not work out... if you still have it at that point. You can email me at adunic@sd8.bc.ca.
Alvin
02-23-2004 16:00:34
Gregg
02-22-2004 09:52:04
A connecting rod .020 under could be hard to find,last year for a Kohler K341 ,I had it chromed and then machined to std.
BCA
02-22-2004 03:16:06
Alvin:
Check ebay for a replacement (link below)
Link
or:
if you wanna go the oversized bearing route...heres alittle more infomation on that process....check out the link below and page down to "Fitting the Connecting Rod with Bearing Inserts"..... .good luck
http://members.aol.com/pullingtractor/engine.htm
TJ
02-22-2004 02:27:50
I have one in the shop with the same problem , a good machine shop will grind it -20 then use a automotive bearing on the rod ---- it works well and will save $$$$$$$$$$$ . have fun .
rICK
02-22-2004 05:44:12
 Re: Re: Need crankshaft or advice for Kohler K341a in reply to TJ, 02-22-2004 02:27:50
A good shop with the right equipment can build it up and regrind to std. I got a K321 crank in now for that. Cost less than fitting the rod with a bearing insert.
