Wheelhorse clutch bearings
Jim
03-01-2004 14:10:53
Does anyone know part# of the bearings in a pto clutch on a 12hp Kohler with 1 1/8 crank diameter, used on wheelhorses?
Mike
03-01-2004 14:37:46
 Re: Wheelhorse clutch bearings in reply to Jim, 03-01-2004 14:10:53
Would help to know the model of tractor, if you mean a C-Series 12hp, I looked up the C-121 and C-125 and the needle bearing inside the back part of the PTO pulley housing is #106769 and is around $12...the ball bearing on the outside is #106947 which supercedes to #109842 and is around $11...
The 1977 and older PTO are different.
Here is where you can look at parts diagrams:
https://lookup2.toro.com/partdex/index.cfm?xCaller=Toro
modre
03-01-2004 16:39:24
 Re: Re: Wheelhorse clutch bearings in reply to Mike, 03-01-2004 14:37:46
the bearing should have a number on it...take to a good bearing house and match it up. manufacturers generally use available off the shelf parts.
I restored a 1956 Flxible Bus w/the original Fageol engine in total fear until I came to understand most parts are generic.
Bearings Inc. has a new name (Applied Technologies?) now...track them down...THEY are THE guys.
