David Bradley Tri Trac clutch disc facing
Bumpas tractors
03-04-2004 18:04:49
Looking for a clutch parts dealer or shop that could supply or manufacture the 5 1/2" dia clutch disc facing that is rivited to external pressure plate on a 1954 model David Bradley Tri Trac garden tractor. Would prefer a dealer located in north central PA or southern tier of NY if possable
Rusty Jones/ The Mower Ma
03-07-2004 09:07:11
 Re: David Bradley Tri Trac clutch disc facing in reply to Bumpas tractors, 03-04-2004 18:04:49
In case you haven't found what you want, go to this web-site, and ask if they could make aclutch disc for you. www.members.aol.com/pullingtractor/clutch.htm They make clutches for Cub weight sled pulling tractors, but they may be able to make a disc for you. Contact them and ask--if not, maybe they can give you some other place to write to! You'd have to send something for a pattern, at any rate! RJ
Bumpas tractors
03-07-2004 11:24:53
 Re: Re: David Bradley Tri Trac clutch disc facing in reply to Rusty Jones/ The Mower Ma, 03-07-2004 09:07:11
Thanks for the info Mowerman but I cannot bring up the web site www.members.aol.com/pullingtractor/clutch.htm you posted. Do you have a tel.number Name and reg mail address for this shop?
03-07-2004 13:33:41
 Re: Re: Re: David Bradley Tri Trac clutch disc fa in reply to Bumpas tractors, 03-07-2004 11:24:53
Note: There is a phone number: Phone: 1-573-875-4033 Rusty J. And an e-mail address: pullingtractor@aol.com
Rusty Jones, The mower ma
03-07-2004 13:26:29
The name of the place is: A-1 Millers small engine and specialty shop. Address is: Brian Miller, 1501 W. Old Plank Rd.,Columbia, Mo, 65203 RJ
