3HP Problem
Dan
03-14-2004 19:48:51
I have a 3HP vertical shaft lawnmower engine that is giving me problems. The engine starts fine and runs, but if I shut it off I can't get it started again. Whats the Problem?
maricopa
03-15-2004 20:02:16
 Re: 3HP Problem in reply to Dan, 03-14-2004 19:48:51
Does it have an engine brake with kill switch on it? If so, cable may be stretched. 2nd thing to check - fuel pump/diaphram. Easiest way to check is to make sure you have spark when it doesn't start. If you have spark, then, spray some WD-40 in the carb.; if it starts, fuel pump problem. Good luck.
