CUB CADET MOD. 102 MOWER DECK
Scott M. Harris
04-07-1999 21:02:13
Hello Don,
I got a mower deck for my tractor. I would have went and got the one from you but I couldn't pass up the offer. "Free" Not a bad deal and the deck is in fine shape. Just repacking the bearings and a genral clean up. I do have a couple question for you though. The idler pulley (non-spring loaded)does it have bearings in it? The one on mine does not turn and seems frozen up. I've soaked it in some penetrating oil but it still won't turn. One more question for you....I torqued the blade shafts to the specified values (38-45 foot pounds") and that seems a bit too tight for them to rotate freely. Is this normal or is there a problem with the bearings themselves??Thanks for the help and the parts I've gotten. Scott M. Harris
Scott M. Harris
04-08-1999 05:46:31
 Re: CUB CADET MOD. 102 MOWER DECK in reply to Scott M. Harris, 04-07-1999 21:02:13
Don, Yes the Mower deck had been outside for some time before I got it. The belts are all but rotten, I'll be replaceing them for sure. I did'nt know that about the idler pulley, thanks. Any other knowledge I should know about, about the mower deck?? Thanks again,
Scott M. Harris
