no charge
,larry in wa
04-15-2004 15:08:22
i have a 10 hp kohler that isn't charging, have replaced the regulator,but no help-i need help-what do i check next? thanks for any ideas.
jim
04-15-2004 17:11:48
 Re: no charge in reply to ,larry in wa, 04-15-2004 15:08:22
pay close attention. 1. do you have 12 volts at the DC post of the regulator?
2.is your battery charged?
3.take off the 2 AC leads and check the output of the leads,at 3600 RPM, should be over 28 volts AC voltage.
4.if your do not have at least 28AC volts, repalce the stator, if you have over 28AC volts and do not have 14.5 DC volts, then you have wiring problems.
5.If you do not have over 28AC volts, also check to make sure you do not have some magnets broken or came loose in the flywheel.
Good luck
