cub cadet low oil light on
Andy B.
04-18-2004 17:06:45
Cub Cadet model 2135. Low oil light stays on.
Changed oil and filter with original parts. Also checked wires they look ok. Changed spark plug and air filter with original parts. Dealer did not give me new oil sensor had only used one. Does not exacly
look the same. Could this be the problem or is there something else. Mower seams to be working fine, I have been running and its not stopping or getting hot. I cut grass about 1 1/2 hours.
Stan
04-29-2004 17:04:27
 Re: cub cadet low oil light on in reply to Andy B., 04-18-2004 17:06:45
Im not familiar with the machine but I just had a problem at work on an engine that the relief valve had a piece of debris in it holding it open causing low pressure.If sending unit and related parts are OK this may be something to check.
Bill
04-19-2004 19:04:10
Sounds like you have a bad sensor or one that isn't compatible. As long as you have verified that oil level is correct on dipstick you won't have any problems. The sensor is merely a safty device to let you know when oil is low.
