12hp kohler
jerry
04-25-2004 19:31:58
i could use some help. my 12 hp kohler will only run with the choke 3/4 on and it sounds like an old 2 cyl. j.d. after running for about 2 or 3 minutes the exhaust gets red hot.
thanks
jerry
Phil B.
04-26-2004 06:32:29
 Re: 12hp kohler in reply to jerry, 04-25-2004 19:31:58
Stuck exhaust valve? Common problem for a "K" series motor.
Marty H.
04-25-2004 20:05:25
Sounds like its running lean or has water in fuel. I would drain the float bowl and look for water.
