14.5 HP BS only runs when choked
Cal
04-26-2004 00:49:54
My rider has a 14.5 HP engine model #287707 with a Walbro carb. It will only run when it's choked. I just cleaned the carb, but did not rebuild it. Should I buy a kit or a new carb?
Mike M.
04-26-2004 10:22:44
 Re: 14.5 HP BS only runs when choked in reply to Cal, 04-26-2004 00:49:54
Try taking lemiter off of adjustment screw & re-adjusting first(if you haven't already)If that don't work then yes,rebuild carb.make sure holes in main nozzle(brass piece runing up center of carb.under bowl)is clear.AS well as seat behind adjustment screw.
