1970 proto. JEEP lawn mower
Joe Plomin
04-12-1999 22:58:17
Help. restoration project. The trans. gear box 4 speed. the only marking is (04 RH ). Who is the MFR.? Any info ? YEAR 1970. Direct rear axle drive. Transfer case also drives blades. Kohler 14 HP k321 reply to jplominsr@aol.com Thanx
Arch Bar
04-13-1999 09:40:50
 Re: 1970 proto. JEEP lawn mower in reply to Joe Plomin, 04-12-1999 22:58:17
I'd like to help, but don't understand your message. Would certainly need more informatio
j oe plomin
04-13-1999 17:39:22
 Re: Re: 1970 proto. JEEP lawn mower in reply to Arch Bar, 04-13-1999 09:40:50
ARCH BAR This is a prototpe riding mower, built in 1970. has a kohler engine 14hp. Belt drives a hybrid transmission, which direct drives the rear axle. Has an internal clutch. The Trans. case has a marking 04-RH. Can anyone identify the transmission (RN123). Who would be the Manufacturer & would parts be available. Also a power take-off gear box drives the mower blades. What other info. do you require?. I have not started the engine as yet. Soon, maybe it works & I will not need parts. Wishful thinking?
Joel Thompson
08-01-2005 15:15:51
 Re: Re: Re: 1970 proto. JEEP lawn mower in reply to j oe plomin, 04-13-1999 17:39:22
I was at a guys lawn mower repair and parts shop and saw that he had a riding lawn mower that looked like a Jeep. It was four wheel drive and the body turned in the middle. The mower deck rode out in front. I can't remember who he said made it but he may be able to help. Outdoor Power in WAYLAND, MI
is the place and his phone number is 616-792-9377. He's a real nice guy and has been in the business for 25 years. He operates normal business hours.
Hope this helps. Good luck.
