5 hp briggs
Ted jr
05-06-2004 14:04:40
I am 13 years old and i have an old 5 hp briggs engine from a sears tiller. I am planning to use it in a go cart. what is the first thing i should do if i wanna get the most out of it for a lower price? thanx for n e help
Shannon
05-06-2004 22:26:43
 Re: 5 hp briggs in reply to Ted jr, 05-06-2004 14:04:40
Do a basic tune-up on it first But the most important thing of all is change oil ""REGULARLY"" use sae 30 wt oil in the summer and you'll get a lot of use out of it
HAVE FUN! BE CAREFUL Shannon
slideways
05-07-2004 04:43:30
 Re: Re: 5 hp briggs in reply to Shannon, 05-06-2004 22:26:43
Change the air filter and make a bracket to bolt on a Cone type like a K&N. Then take off your muffler and screw in a piece of galvanized plumbing pipe about 9-12" long. Make sure the carb throttle butterfly is opening perfectly flat inside the carb so you have wide open throttle. This is a basic hop up for a Briggs. You have to start taking it apart after that.
www.4cycle.com
