1969 JD 140 VALVE CLEARANCE
DICK CUMMINGS
04-13-1999 17:33:32
I NEED INFO ABOUT SETTING THE VALVES ON MY 140 WITH A KOHLER 14 H/P SAME YEAR AS TRACTOR THANKS ALSO ANY INFO ON REAR PTO SETUP + 3POINT HITCH
David Castiaux
04-13-1999 21:42:23
 Re: 1969 JD 140 VALVE CLEARANCE in reply to DICK CUMMINGS, 04-13-1999 17:33:32
A good place to get the spec's on your engine is at,http.//www.yetmans.mb.ca./ Good luck, David in OKC
David Castiaux
04-13-1999 21:36:51
A good place to get spec's on your engine is, Link good luck David in OKC
mike
04-13-1999 17:41:16
.008 on the intake, .017 on the exhaust with the piston at top dead center on compression stroke.
