15.5 Briggs Stratton No Spark
Charlie B
05-21-2004 21:16:01
My Sears tractor with a 15.5 briggs stopped dead while mowing. It will sometimes backfire very loudly when trying to restart. This has happened a few times this season. Now I have no spark at all. Any ideas were to start.
Dave
05-22-2004 07:43:15
 Re: 15.5 Briggs Stratton No Spark in reply to Charlie B, 05-21-2004 21:16:01
Charlie,
The backfire could be a carb problem, but if you get no spark also here is a list of a few things I can think of.
1. check carb excessive rich setting\
2. check all wires leading from ignition system, for grounding or bare wires.
3. check flywheel key to make sure fly wheel is not slipping on shaft, this would cause out of time issues and could also be your backfire problem
check these things,
Dave
Charlie B
05-26-2004 04:10:15
 Re: Re: 15.5 Briggs Stratton No Spark in reply to Dave, 05-22-2004 07:43:15
Dave, thanks for your no. 2 suggestion. I found a pinched wire coming from the magneto pinched behind the starter motor. All set THANKS!!!
