14 Hp Briggs
Ross
05-22-2004 08:53:40
I have a Lowes MTD with a 14 hp Briggs OHV engine. It starts very hard while backfiring out the carb. After I get it started, it runs good. I assume the valves are out of adjustment. I haven't been able to find a manuel locally. I need instructions on checking and adjusting the valves. If there are any other ideas about this problem, I would appreciate hearing them!
bstrucker
05-23-2004 18:55:49
 Re: 14 Hp Briggs in reply to Ross, 05-22-2004 08:53:40
Has it done this since you started it this spring?It sounds like your intake valve is sticking in the guide.They get varnish on them from old gas.Try shooting some WD40 in the carb,The engine will run on it,and it should clean of anything causing the valve to stick.
J.C
05-23-2004 19:24:49
 Re: Re: 14 Hp Briggs in reply to bstrucker, 05-23-2004 18:55:49
If what Ross said doesn't work try taking out both valves and grinding them down to were theirs a gage of 10 in between them.
