BRIGGS TWIN
TJ
05-25-2004 17:45:17
Can someone tell me if the push rods on a Briggs twin are the same length I just rebuilt this engine and they all fell out while I was working on it ,I stuck them back in but didn't check for a difference in size . Now I can't get it to run (acts like valve timming)
bstrucker
05-25-2004 18:58:34
 Re: BRIGGS TWIN in reply to TJ, 05-25-2004 17:45:17
Ther is a good chance that they are not the same,most of them vary by a few .000.You should pull the breather off and check your clearances.If they are off you need to file the valve stem to get them right.
Kent of SW MO
05-25-2004 18:12:03
On B&S singles with overhead valves the intake push rod is the aluminum one.
