BS 16hp 401707 Compression question
Mike381
05-27-2004 06:58:34
What should the Compression be on this model. I have 80lbs on one cylinder and 90lbs on the other. This motor runs but dies when I put it in gear. I have cleaned the carb, replace filter and gas lines. Spark seams to be weak on both cylinders. One plug is black and the other is clean. Suggestions?
Kent of SW MO
05-28-2004 07:00:53
 Re: BS 16hp 401707 Compression question in reply to Mike381, 05-27-2004 06:58:34
Check you safety interlocks.
bstrucker
05-27-2004 19:37:44
The black plug should be the problem.Start by putting in new plugs.10lbs. difference in compression shouldn't be a problem.I'm not sure on that model engine,unless i look it up,if it has 2 coils or not.It could be a sparkplug wire or coil.It doesn't sound like something inside engine,given the compression readings.
