Case 444 Garden Tractor
Matthew
04-16-1999 22:45:21
I own a `80 Case 444, with Kohler 14 horse power engine. The engine is worn out, after being rebuilt twice. I would like to upgrade to a 16 to 20 hp engine, but not sure if any companies make an engine with the same bolt patterns my Kohler had. It had a 1 1/4 inch long, one inch diameter shaft with a 1/4 inch keyway. Does anyone know if Onan still makes engines that would be a bolt in swap, with out buying new couplers and a different clutch assembly? A dealer told me Kohler doesn't make my 14 hp engine any more. Any info would be of great help. Thank you!
Ken
07-05-2004 00:08:40
 Re: Case 444 Garden Tractor in reply to Matthew, 04-16-1999 22:45:21
Not sure if you still have the Case - but interestingly I have had one sitting around here with a blown engine for a few years now. I have just recently (like last week) purchased a bigger engine for mine - used. The old Kohler was only a 12 horse. I had pulled the 46 in. mower off and re-mounted it under a Cub Cadet (LOL I know pretty weird - but sure cuts good) My point is I didn't need the front drive anymore - just the rear stub to run the hydraulic pump. The engine I bought is a 20.5 Briggs engine - and the shaft is identical thickness with the same keyway. The shaft is little longer - which will be fine as I will now have to hang the pump off the bottom of this vertical shaft briggs. So will need some extra clearance and length to do this. On another note - the Briggs mounting holes on the engine match the width of the case frame. Everything points to this being a pretty good match. Except I don't know about RPMs at this point and how that will affect the pump drive for the tiller and the hydrostatic trans.
Ken
Lyle Ourada
04-28-1999 13:44:52
I own a Case 444 with a 14hp kohler. The engine blew several months ago. I wanted to replace the engine with an updated larger engine but was unable to do so.
I ended up purchasing a new short block.
Your biggest problem is none of the engine manufacturers make an engine with a shaft at both ends. One end drives the hydrostatic pump and the other drives attachments. During my search: It may be possible find an engine for the pump but to drive the attachments, I was told, you could change these to electric drive.
Most places I talked to were able to find the short block.
Jim Oatey
03-09-2001 19:53:52
 Re: Re: Case 444 Garden Tractor in reply to Lyle Ourada, 04-28-1999 13:44:52
How much did your short block cost? I have a 444 with a bad engine too. Also, what type of place do you find a short block? Thanks
estickney
06-12-2002 17:55:21
 Re: Re: Re: Case 444 Garden Tractor in reply to Jim Oatey, 03-09-2001 19:53:52
The Case 444 does not have a double shaft engine. There is a stub shaft which bolts to the flywheel. I replaced the short block on mine. I bought it from a Koehler dealer.
mike50_4a
05-03-2003 13:30:24
 Re: Re: Re: Re: Case 444 Garden Tractor in reply to estickney, 06-12-2002 17:55:21
what is the model and spec #s for the 14hp short block
my engine is getting very tire and was rebuilt previously and the id tag is gone from the cover
any help will be appreciated
thanks Mike
