'67 JD110 replacement motor needed or advise...
wild
06-24-2004 07:21:35
Blew the motor on my JD110. Anyone have a replacement motor near Lexington, KY?
Or what can I replace it with other than the original Kohler 8hp?
Should I use this "opportunity" to up it to a 10 or 12hp motor?
Thanks in advance,
Wild
Chad
06-25-2004 11:36:13
 Re: '67 JD110 replacement motor needed or advise.. in reply to wild, 06-24-2004 07:21:35
I would take it apart and see what is damaged. Have the crank turned and put in a new rod, piston and rings. These are collectable tractors worth restoring.
Chad
06-24-2004 18:28:15
When you say blew the motor what exactly happen. Threw a rod?
wild
06-25-2004 04:33:19
 Re: Re: '67 JD110 replacement motor needed or advi in reply to Chad, 06-24-2004 18:28:15
Yes threw a rod I guess. Last couple of times that I have mowed it had started losing power going up hills. If I would move the speed control back the rpms would go back up. This last time I got maybe 20' and it started losing power, I disengaged the blades, rpms shot back up, followed by a "Boom!....Ping, Ping, Ping" (How is THAT for technicle information?) She just spins now.... Thanks for all of the info..don't know what I should do. Any body need a parts buggy?
Andy
06-25-2004 04:41:08
 Re: Re: Re: '67 JD110 replacement motor needed or in reply to wild, 06-25-2004 04:33:19
Email me with your price. I'm looking for a parts tractor...
Wally G.
06-24-2004 18:14:30
If you want to update it, you will have to get it from a newer 110 or 112 because they have a special flywheel and blower housing to fit the frame cutout. You will also need to convert from a starter/generator to the alternater set up.
Ron
06-24-2004 09:35:34
Put a 502 Chevy in it!
Just kidding!
See www.northerntool.com. UPS brings them right to your house. Hint: Buy a Honda or B&S.
