opions on JD L110
1Appy
06-27-2004 23:07:02
I'm looking at buying a L110. I have 1 acre of yard to mow, it's pretty much flat. and 1 acre of pasture to mow every now and then. it's flat also, but uneven ground. Any opions on this mower? I have a White Lt14, and have had some problems with the front wheel. I don't want to spend more than $2000.
pdi man
06-28-2004 17:02:53
 Re: opions on JD L110 in reply to 1Appy, 06-27-2004 23:07:02
L110 should do the job ok. is just entry grade unit, so don't abuse it much. if you can find one, go with the L118. the extra horse pulls the 42 manual deck a lot more freely. and the bigger tires and seat make for a better ride. i have recently found that the front axles can be bent in large holes. cast iron can be bent a bit. also keep in mind that the L series blades aren't the thickest, and can be bent as well. the unit is comparable to the sears units (buddy just got one--red--looks pretty decent).
