You can look at, or download for free, a factory manual at: www.kohlerengines.com With the timing marks, if they line up as shown, that's it. When the crank turns 360 degrees, the mark on the cam will be 180 degrees off, but when the engine turns another 360 degrees, the marks will line up again, so you're OK there. Have you retorqued your headbolts after it has run? If this is a breaker point ignition system, spark timing is set by varying the breaker point gap. (See Kohler manual) Have you checked the timing with a light? Are all pieces of cooling shroud sheet metal present, and properly installed? I suspect you may have a bad ignition coil, and are loosing spark when it heats up. Also, you could have a fuel system problem, such as a restriction somewhere in the tank fitting, or lines, or a clogged gas tank vent. Has the engine been rebored and/or the piston replaced? If there is not enough piton-to-bore clearance, it could begin to seize up when hot.
