70 Cub cadet with K161 got me stumped
Midnight
08-02-2004 05:02:10
I put a new clutch in 70 over weekend and when to start her up last night and wouldn't start. Check everything over thought maybe banged a wire or something. Finally put spark plug tester on spark plug and she started like a dream. As long as I leave the plug tester on she starts and runs. Put plug wire on plug and won't hit a lick. I replace plug wire and checked plug and still won't run unless plug tester is hooked up. My plug tester is a NAPA one where you adjust spark length and hooks on top of plug. Anyone have an idea, I need to mow tonight. Thanks
Deere John 2004
08-02-2004 15:34:03
 Re: 70 Cub cadet with K161 got me stumped in reply to Midnight, 08-02-2004 05:02:10
If your K161 has a breaker point ignition system, try checking and setting the Breaker Points to .020. This sounds like a problem of a weak spark that will not jump a gap under compression. If the points are not opening the correct distance, the condensor doesn't store enough energy to make a good spark; when you make it jump another gap, your spark plug tester, you are correcting this problem. In the "old" days this was setting the dwell angle. LOL, PJCW.
midnight
08-04-2004 05:44:04
 Re: 70 Cub cadet with K161 got me stumped in reply to Deere John 2004, 08-02-2004 15:34:03
Thank you for your help. I regapped the points and grass is mowed. Thanks.
Chad
08-02-2004 05:07:18
Start with the easiest and replace spark plug first.
midnight
08-02-2004 08:16:28
 Re: 70 Cub cadet with K161 got me stumped in reply to Chad, 08-02-2004 05:07:18
I replaced the plug and no differance.
